The FANUC M-710iD/70 robot model is not available in the software library. I hope supporters can provide this component. Thank a lot
The model you are asking is already there. It was added in 4.10 eCatalog on May.
If you have an older software version, you need to upgrade to latest version in order to get access to new eCatalog additions.
If you are already using the latest version, something has went wrong in eCat synchronization, and you need to force-update the catalog by running the program C://Program Files/Visual Components//VisualComponents.eCatalogue.UpdateWebCat.exe .
Hello, I am currently using version 4.9. Could you please provide a component that is compatible with version 4.9,Thanks a lot.
if you have a valid maintenance, you can ask to upgrade to 4.10 to get all the new components which were added in the eCatalog ![]()
