Hello I was following the academy video to try to connect robo guide to Visual Components however it is not working.
when I got into the connectivity tab it does not find my robot controllers
I have roboguide running on the same machine. there wasn’t any more information on the video
so no idea where to start trouble shooting.
Robot Neighborhood Discovery uses the same functionality as Fanuc Robot Neighborhood from which you can configure robot and its network location. If you do not have any robot defined in the neighborhood then you have to let the neighbors know.
My RoboGuide has dust on it, but testing showed in my PC that the robot server for the neighborhood was blocked by security.
Long story short, by default the IP address of robot in RoboGuide is your PC IP (12.7.0.0.1 might also work with VRC). If you cannot directly connect to the controller then reinstall RoboGuide and try again.
