I have an issue with a TransportOut process statement in PM while using Execute Routine as Robot Motion and the next process where the parts are transported to is just a buffer. There is a while loop with the condition that it is executed twice. Everything works fine and on the first run the TransportOut statement even works, but on the second run of the loop the process gets stuck on the TransportOut statement and I get the following output in the console:
File “RobotController::ResourceLogic”, line 117, in OnRun
File “RobotController::ResourceLogic”, line 1567, in execute_next_action
File “RobotController::ResourceLogic”, line 157, in execute_pick
File “RobotController::ResourceLogic”, line 723, in pick
File “RobotController::ResourceLogic”, line 1218, in get_transport_data
AttributeError: ‘NoneType’ object has no attribute ‘Source’
Thank you in advance.
