Facing an issue with the AGV picking up cut samples.
Hi Visual Component Community,
I am currently using Visual Components to simulate a cutting production line. Ideally, when all cut samples (e.g., 5 samples) are ready, an AGV should come and transport all of them to the next process. However, in my simulation, the AGV comes to pick up only one sample at a time.
I have defined the statements so that the AGV should be able to bring 5 samples to the next process, but it doesn’t seem to be working as expected. I have attached the layout file.
Does anyone have any ideas or suggestions on how to fix this?
Thanks in advance!
bandsaw-simlation.vcmx (670.7 KB)
Define agv capacity as five,
Process nodes should use StartTransportIn and WaitTransport rather than TransportIn.
I’m not sure if it’s the right answer you want, but I hope it helped.
This is the test layout.
example_bandsaw-simlation.vcmx (623.0 KB)
Hi John,
Many thanks for your help. It works. I didn’t realise the difference between StartTransportIn and TransportIn.
Hi HyeokcheolKwon,
Yes, this is exactly what I want. Many thanks! I realised in the attached model, you defined five StartTransportIn statements, I am wondering if there are some functions in Visual Components we can use to only define one StarTransportIn and store five products and then transport them to the next process? Thanks.
Hi, Zhen.
As of now, the only method I can think of is the one I previously mentioned. If I find a new approach in the future, I will let you know! :slight_smile:
Hi, Zhen.
I tried checking the VC Academy to find a new answer to your question, but aside from the response mentioned above, I couldn’t find any additional ideas.
However, I think the following VC Academy video could be a helpful reference:
https://academy.visualcomponents.com/lessons/load-and-unload-assist-by-using-another-resource/
Have a look at the layout “Batch Transport” in “Layout Templates” in the eCat.
It shows different ways to transport several products at a time. In the example it’s done with humans, but it would work the same with AGVs.
Hi HyeokcheolKwon,
Thank you very much for sharing this link. It looks like a useful reference.
Best regards,
Zhenyuan
Hi Tilma,
Many thanks for letting me know this relevant Layout. I will try to use the similar transport method for AGV.
Best regards,
Zhenyuan
