Any idea how to fix this problem:
Export has been aborted. No file has been created.
** Exporting error: -10400…**
That’s what I’m getting every time I try to export a model. I can only export in 3ds format but nothing else…
Cheers,
Cheers,
Are you at least able to import files from those format you cannot export? cause I guess underneath is the same library.
Yes, I can import every kind of format without a problem and the strange thing is that this happens with only one of my files.
I guess better if you create a support ticket with the file you cannot export, seems like a bug
