There is an obvious strobe phenomenon when using the blender plug-in for video export. what may be the cause of this, and what is the recommended solution?
I noticed that this usually happens when your 3D models have many surfaces on top of each other.
The fix would be to remove or offset any overlapping geometries so that the Z-fighting does not occur.
Thank you very much for your answer. I checked my scene and the strobe is really because the faces of the two components are in a state of close overlap. Thank you again for your answer!
