Excel interface
I would like to use Excel sheet as a simulation interface to introduce all the simulation parameters, I saw in the forum that we can create CSV files and import them into Visual Component, but this is not what I would like to do. The simulation interface on Excel would have a tab for each machine with parameters like Setup Time, machining Time, TransportIn, TransportOut, … and using a button on Excel, it pushes the values to the right variables. Also, I would like to read values from Visual component to Excel, This will help developing Dashboards displaying any information.
I know that everything could be done by programming, but I am looking for a simple way to open excel, fill a few cells with values and variable names, press a button to push values to simulation and press another button to get values from simulation.
Best regards
Check the Excel Reader component from the eCatalog Misc folder. It probably cannot do everything, but it’s a good starting point.
VC doesn’t have any external API that would allow you to command it from another program such as Excel. It would be possible for you to develop such API using a .NET add-on, but it is much easier and better overall to just import and export data from within VC instead of trying to use something like Excel to control VC.
