Error: Object reference not set to an instance of an object
Hello Visual Components community!
Have you ever faced the error "Object reference not set to an instance of an object ", when Robot is selected and you try to go into the Robot Settings from the Programming tab?
That happens first with my GP25 Yaskawa robot. Then I tried different robot models, from different brands, to add them to the layout, delete the existing robot, and add a new one, but nothing helped. Then when I click on Gantry or Positioner - same error, so something is broken in the project. Error description appears on the Output tab, so the layout is not crashing.
Any ideas on how to fix it if at all possible?
Thanks!
With best regards,
Vitaliy
Seems like a bug in VC OLP specifically (former Delfoi robotics functionality). Probably would be best to just report that to VC support.
