how can I embed the viewport of NG in another application?
br/Ralle
br/Ralle
Hello Ralle,
Unfortunately this is currently not possible, and the whole feature is still in research phase -> wonāt be available anytime soonā¦
Ā
Hello, are there any news about the issue? br/Ralf
Ā
Hi
I also like to encourage you to publish an open interface for the viewports.
that would adress cool opportunities, f.e.:
As far as i understand the current āsharedā API:
1.) Itās possible to create a 3DWindow with own Camera/View- Setting via IApplication.Create3dWindow() and manage them via (Delete3DWindow/ActiveWindow/Windows)
2.) Itās also possible to set the newly created 3DWindow via IViewPort.SetWindow() as active
Problem here is that modifying IViewPort just affects the UIElement of the VC-Application (IViewPort.RootElement) = System.Windows.Controls.Viewport3D
I didnāt manage to ādetachā or ācloneā the IViewPort.RootElement from the VC-application into my application.
It would be great if IViewPort could publish for example an UIElement of type (Viewport3D)???
Thanks
Hi
I manage to show the IApplication.ActiveWindow in a separate Window, but iām not satisfied with the solution, because itās not the viewport itself. To those who like to review the code⦠be warned⦠started .net 5 days ago. If you come up with a better solution⦠please share.
Problems:
I didnāt tried to get a better performance:
-Direct3D UI stuff like SharpDX etc. for visualisation
WpfApplicationShowRenderImage.zip (57.4 KB)
Thanks maik for sharing. I totally agree with you about the support for 360 video player, VC and AR type of use cases. Itāll probably need a little different type of approach from VC side.
The support for the multi viewport support is basically still in the same state as Gargamel earlier stated. Itās in a research/development phase. You might get some things already working as you managed to do but support for navigation and handles (etcā¦) is not quite done yet. So for the time being Iād recommend to wait⦠otherwise youāll keep banging your head on a wall.
Hi eme,
thanks for reply to my investigation. As you mentioned, there are some parts of viewport already implemented. Is there any chance to get into a āfast ringā of beta releases? You may contact me also via email:
maik.poggendorf@iff.fraunhofer.de
thanks
Maik
Are there any news about the embedding possiblities research? In version 2014 it was a big strength to embedd the viewport in other applications.
Thanks for showing this example.
I have a little different goal. Instead of exporting the display to a different application, I want to display a second 3D graphics window in my VC application so I can have 2 views side-by-side.
The naming implies that IApplication.Create3dWindow() would be a display ready element, but I cant seem to show it on the screen.
Does VC have the capability to display 2 3D windows?
Is this the āmulti viewportā that eme indicated is still in research/development?
I would love to be able to add multiple Windows at the same time, each with a different camera, to achieve a multi-angle, partial display of the same project. Can you provide demo code? thank you
