I would like to ask if there are any machine/station components in the Visual Components library that support changing the size of the station directly in Properties.
For conveyors, I can change parameters such as length, width, and height. However, for most machine/station components I tried, I either do not see editable size properties at all, or the fields are locked.
I am looking for a simple station/machine component where I can modify the dimensions of the main body (for example length, width, or height) without having to create a fully custom component.
My questions are:
- Are there any standard library machine/station components with editable dimensions?
- If yes, what are their names in the library?
- If not, what is the recommended way to create a simple station with adjustable size for a production line project?
Thank you.
