Why is it that when I use a welding torch to complete the process, TCP will automatically cut into DynamicTool when the program is running, which causes the TCP I set in advance to change, resulting in a change in reachaability? How do I set it up to keep the TCP I used when the program runs.
Look forward to hearing from you all.
Best Regards.
