how are the imported entities of an dxf file are bundeld into the Features?
By layers or blocks or what?
Thx & Regards
Thx & Regards
That is a good question.
As far as I understand, the reader does not act the same way compare to other cad formats. This is because a DWG or DXF file might contain huge number of entities. In this case, the reader tries to group entites of the same time into a single geometry feature (one for frames, one for polylines, one for meshes, …)
It might also create additional features (transform) for each block if you have the option Feature tree = Full
Hy @ccamilo ,
organising the Features by blocks sounds great…
The dwg Attribute Reader in 4.4 also sounds interessting in this Case.
VC does not make this at my PC!?
Thx Reagards
Hy @ all,
is there a way how the dxf should be created that I can influence the feature organisation when importing dxf?
I would be happy if there is a way…
I’m free by defining the dxf with layers or blocks!
Thx & Regards
