I want to implement drag and drop functionality from my Add-on into into the world of Visual components (similar to the ecatalog functionality)
Is there any information available how to implement this?
Thanks in advance!
Thank you. Looks very promising.
Do you know were to find this object in code?
Sorry, My question was not clear.
I want to catch the event if something is dragged from my addon to the main VC viewport.
Creating a new object from this class, is not linked to the main viewport.
Do you know where I can find the object of this class, where the event for the drop is raised.
The first options (var m) does not provide the ‘drop’ methods.
The second options is not triggered when I drop something in the main view.
hmmm and what happens if you set:
HelperViewport.ActiveViewport = m;
before subscribe to event?
If this is also not working may a VC member could give a hint?
This gives an error as the types are not compatible. Even explicit casting to the correct type is not possible.
which Type ist expected?
Not sure if it works, haven’t tested, but you could try something like this:
var viewport = IoC.Get<IViewport>();
if (viewport != null)
var frameworkElement = (viewport as Screen).GetView() as System.Windows.FrameworkElement;
HelperViewport viewportHelper = frameworkElement.FindChild<HelperViewport>();
// use the viewportHelper here
Thank you.
This works perfectly!
