Doubt in process statements
BPP simulation1.vcax (1.3 MB)
Hello, I am new to Visual Components. I am stuck with process simulation:
Laser Cutting Process:
Feeder (Square plate)>from conveyor>to conveyor(thru Robot)>worktable>laser process (change to circular plate)> from conveyor #2>to conveyor #2(thru Robot)
Kindly help me with process statements
Pls check the attachments:
I don’t really understand your Attach and Detach statements. What is the variable “TableTop”? I don’t see it defined/created/transported anywhere. It’s supposed to be a product.
And the ChangeType statement changes the ProductType, not the variable name associated to this product, so you should still use the name “CS-Sheet Metal” for the TransportOut at the end of the Worktable process
Thank you. It works now…:slight_smile:
