I have a basic question and I really can’t find any documentation.
I have a script that opens a file with the joint values of a robot and passes them on to the robot in VC.
It works quite well.
The next step is to be able to select the file I want to open, without having to go through pythonscript. What I normally do in python is to use filedialog.askopenfile from Tkinter, something that is not supported in VC.
I was able to found the dialogOpen command but, as I am really now starting with programming, I cannot understand how to use it.
If someone could point me in the right direction it would be great!
Thank you in advance
