Hey guys,
I want to simulate an axis on which a sledge with a weight on top can be moved from the left to the right. Therefore, I linked the sledge to a servo drive and added a physical behaviour which I set to “kinematic”. The weight on top of the sledge is fixed with a physic joint and set to “in physics”, as I want to check how much the component will be moved from the fixing point when the direction is changed. Additionally I wanted to add some sensors which are detecting the “in physics” defined weight when is crossing it, which does not work.
My questions are now:
Is it possible to use a sensor to detect components which are NOT moving on a defined path like the TwoWayPath, OneWayPath or PhysicalPath, but which are moved with a ServoDrive ?
Furthermore it would be nice to know if objects which are defined as “inPhysics” are able to be detected by Sensors if they are falling down and crossing these ?
I hope you can understand my explanation and the questions
kind regards,
John
