Dear VC forum,
Currently I’m trying to model my own end-effector (image included). It’s supposed dispense round eatingpaper from the cartridge above the rotating vacuumtool. Goal: The link grabs one paper, rotates and releases it when the rotation of 180 degrees is done.
Pardon my lack of knowledge of VC, i’m new and learning. The rotating link grabs one paper and rotates 180 degrees. The problem occuring is that the paper is attached to it’s parent node, the rotating tool (link_4). When I use the detach button in Home -> hierarchy, the paper is released and I can use my grab/release tools pick and place further. But if the paper is attached to the parent, it stays attached to link_4, even if I release it with my tool.
Is there a python way of releasing the paper into the world (just like the detach button)? After this I could just use my tool to grab/release the paper.
Code in end-effector:
#script for 180deg toolrotation
from vcNode import *
from vcServoController import *
from vcContainer import *
app = getApplication()
node = comp.findNode("Link_4")
container = comp.findBehaviour("ComponentContainer")
graspcontainerlink4 = comp.findBehaviour("GraspContainer_vacuumCompleteToolVisualComponents_Link_4")
movetime = comp.getProperty("motionTime") #motionTime in Properties
servo = comp.findBehaviour("Servo")
gosignal = comp.getBehaviour("TurnSignal")
donesignal = comp.getBehaviour("TurnComplete")
def OnRun():
servo.moveImmediate(0)
while True:
triggerCondition(lambda : getTrigger() == gosignal and gosignal.Value == True)
#pick label
label = container.Components[0]
graspcontainerlink4.grab(label)
ouwel = getApplication().findComponent("ouwel")
print(ouwel)
#reset rotation
if (servo.getJointValue(0) < 360):
servo.setJointTarget(0,servo.getJointValue(0)+180)
else:
servo.moveImmediate(0.0) #moves to 0 degrees in 0 simtime
#rotate
servo.setMotionTime(movetime.Value)
servo.move() #start turning
donesignal.signal(True) #done turning
delay(0.01)
donesignal.signal(False) #signals off
gosignal.signal(False) #signals off
pass
