Cycle Time Calculator
Hey guys,
Is it possible to use a single cycle time calculator to measure all ports and list them seperately? Also, renaming the listed cycles would be great.
I want to measure multiple trajectories of a robot and dedicate only one cycle time calculator for that robot.
Hi Zero
We made an adaption of the existing Cycle Time Calculator.
This version calculates min/max/avg values individually for each port as well as the overall min/max/avg values. Hope this helps.
CycleTimeCalculatorAdvanced.vcmx (117.6 KB)
Thank you @ProLean !
This sounds exactly like what i am looking for. However i couldn’t find how to activate that feature.
Can you point me to where i can activate the calculation of individual ports?
Mine only shows a single min/max/avg value set even though i connected multiple ports.
Ah yes I see, thought we implemented this feature.
Are you familiar with Python? You could change it to use the port number instead of the component’s name.
I’m somewhat familiar with python, but I’m struggling with VC python API.
If you can show me an example, I would be very grateful!
