I am currently working on a custom machine i modeled in cad. My problem is the process the machine is supposed to execute. The products i get from the transportIn process step just dont stick to the product frame i reserved for them. I want the products to be moved by the machine parts. The movements themself work just find on a dry run of the machine. But the products just stick to their initial positions as the machine parts move to the wished extend (and clip into the products). Any suggestions?
I guess workpieces is not attached to the moving node, reason could be many, it would be easier to check with layout, you could delete the CAD, use a block or sphere to replace.
Move ComponentContainer to Link1 or Link2, select TransportNode set ComponentContainer again, due to you changed ComponentContainer to different node, but it seems like your 2 workpiece belongs to different node? If it is, I think you might need create 2 TransportNode.
