What would be the most elegant way to solve the following problem?
I have an upper and lower line, the upper one runs into a buffer and the lower one runs straight out. When the buffer is full, I would like station 2 to feed into station 3.
Currently I do it by interpolating transport.
Is it also possible to do this with a crossing conveyor?
oh I may have expressed myself incorrectly.
in terms of the process etc. everything works, I meant more in terms of design. as the plate currently only flies from line 1 to 2. did you think you could solve this with a crossong conveyor?
thank you very much, but the process flow works for me
it’s more about the layout i would like to have a rotated conveyor between station 2 and 3 is this possible? since the parts are currently flying at this point, which is actually not possible in reality
thank you very much, that was exactly my question, whether it is also possible without curve conveyor or corssing coonveyor. but i think then that will be the only way to get the shifting done
