I am trying to create a system where 4 pallets are grouped together with a 5mm difference between the pallets and then sent through the system as a group of 4. I have tried this with the works library however this causes issues with the interaction with the process modelling components downstream.
I have tried to work get the transportpatternin function (similar to the works library statement) however i have not been able to get it to interact with the products produced by a feeder.
have you tried it with an assembly in process modeling? you will find good instructions for assemblies like the basics:
in your case with transportPatternIn:
do not use the feeder with transportInPattern statemwnt, but use a process node downstream
with transportIn and then three more pallets via transportPatterIn statement
Then use the attach statement…
Hi Anhu,
So the process node would be something like
Transport in
Transportpatternin 3
attach
transport out
Is that the approximate correct order?
I have tired this but the pallets wont stop on the node. Do I need a transport controller even when I am not using a robot or a manual interaction?
Hi YDO,
did you specify in your TransportIn statement that the source is a Component Container? That way it knows something comes from the conveyor, and not from another Process
