Hello everyone. We have set up 3 2 way conveyors in a row and put some boxes on it and run in 2 directions. Normally everything is fine so far but after adding the 7th box, there is a bug that only the first box can move, the others are blocked by the 2nd box in the 2nd conveyor even though it has the correct speed and direction. Does anyone have an idea and show me how to fix it? Thanks a lot. I also have a picture to describe what I mean. Happy New Year everyone. Happy New Year everyone
Maybe the path axis goes wrong for some reason, and the path thinks the boxes are lying on the long side. Hard to know the real problem without inspecting the simulation file.
I will prepare simulation file. One more question about Twowaypath properties Accumulate and Space Ultilizations, I set them to False Value but when I start Simulation, they are autimatically set to True Value. Is that normal ? ![]()
That should not happen. Maybe there is a script somewhere that controls these properties when the simulation is started?
Oh I see, the scripts use component properties to set Value
I’ve changed them to False.
I still dont know where this bug from so I replaced 3 conveyors by only one and simulation can run perfect :3
