Copying Views Between Models
Hello All!
Hopefully a quick solution to this one. I am working in multiple ‘phases’ of projects, and I want to string together a video of each phase working. I have elected to split each into different models, but I neglected to create a view first. Is there a way to plug in exact numbers for a view to ensure they match? Or is there a way to copy a view over?
Any advice much appreciated!
Hoping to bring this back to the front page…
I found a workaround where I delete everything out of the file except the view and then drop that into the other models… Is there no better way?
Can you try this component? : Views Export Import.vcmx (46.4 KB)
If you click on “ExportViews” it will write some informations in this component’s note.
You can copy the text, then in a new layout, paste the text in the note and click on “ImportViews”
It will delete existing views and create the views from the other layout
This works as intended!
Thanks,
Keynan
