I am new here and need help for copy and paste an entire sub program to another sub program !
Also any kind of documentation about manipulating the statement in these Sub program will be helpful
Hi!
You could export the subprogram as XML and then import the XML in another robot.
i don’t have the option to export in any extension.
Then you are probably using an old version of the software? You could try if the exchange robot button works for your use case. Another way could be to write a python script that can copy robot routines.
thanks Este,
rigth i am in an old version. I don’t understand the part of exchange robot even if i have the button.
i want to try the python script and it will be helpful if you show me where to start.
