Hi All,
I like to have a conveyor which has a certain speed interval interval. Sort of a intermittent profile.
Pleas see the profile attached
Hi All,
You could use the acceleration and decceleration attributes of path behaviour or just write a script in python for example:
speed = 0
max_speed = 0.33
path = comp.findBehaviour("path")
while speed < max_speed:
path.Speed = speed
speed += 0.05
delay(0.1)
Didn’t check it but should prob go like that
Ok thanx for you answer
Is it possible to make a function in python which makes the belt move 400 mm each step?
