Can someone point me in the right direction for creating a small section of conveyor that will bump turn my product 90 degrees? For my product, I was planning on just using a basic shape (box).
Should I be using a Conveyor (Physics)? What should I use as my bump turn device?
Hello! Can you please tell is there any possibility to make a rotation optional? I mean in product flow sometimes I need rotation, sometimes I am not. For example: 3 boxes go through the conveyor directly, next 3 rotated 90 degrees on Z.
Thanks!
maybe you can work with process nodes.
Define your own logic there, whether destination is it to next process (next process works with offset Rz=90° in a TransportPatternIn statement) or destination is to the component container
