Hello guys,
I’m trying to model a conveyor with a diagonal incline and I think I did, but I can’t seem to find a way to
make its path diagonal also.
Any suggestions?
I’ve attached an image of the conveyor.
Cheers and thanks in advance!
Hello guys,
Any suggestions?
path consists of frames, maybe you can rotate them a bit? ![]()
I tried that.
It changed only the PnP attach, if I place a Feeder infront, the products are moving in a straight line, without any angles.
Am I missing something ?
Cheers
did you look at the frames from pathfeature as I recommended?
Yes, I only have Start and End frames, that’s all.
Cheers.
Maybe you need to disable “retain offset” on the path, or alternatively make the feeder’s frames also tilted.
