Connectivity Configuration Helper - Siemens S7
This addon aims to automatically create variable pairs for the S7 connector in Visual Components. The functionality is similar as the ADS helper ( Connectivity Configuration Helper -Beckhoff ADS ), but there is no need to create a separate pairing Excel file.
This addon uses the PLC tag list exported from TIA-Portal as input, and searches the simulation for components, behaviors and properties for similar names as the PLC tags.
The variable pairing logic works as follows:
Attempts to find a simulation variable that matches the tag symbol name and type
  1. See if the tag should be connected to a servo Dof.
  2. If no match found, attempt to find a match from behaviour of given tag type.
  3. If no match found, expand search of properties of given type.
  4. If still no match, go through all properties and all behaviours once more to see if any names match
If the pairing is successful, the addon generates a ServerConfiguration.xml file. This file can then be imported to Visual Components using the Import Configuration button on the connectivity toolbar.
Download and extract the addon to the My Commands / Python 2 folder.
S7ConnectivityConfigurator.zip (10.4 KB)
Notes:
21.1.26: Fixed a unicode character problem with folder paths
Similar addon available for Beckhoff ADS: Connectivity Configuration Helper -Beckhoff ADS
Thank you for creating this, I’m sure it will be of great help for other members too!
Personally, we are aiming to connect our Siemens PLCs over OPC UA. Do you think that such a configuration helper add-on will have to differ greatly from the ADS & S7 versions you made, or would it only be small connectivity differences?
