I have ERROR when I try simulation my simple project, please help me, why Visual Componets cant write value to PLC project? I dont have physical PLC, I use PLCSIM with Nettopclsim:s7o, TIA Portal v15
Impossible to say anything without more information. Does the output panel or the VC engine log file have any related error messages?
where can i find this file?
Similar to:
C:\Users\%username%\AppData\Local\Visual Components\Visual Components Premium 4.2\Logs\
My guess is that you have some configuration issue in PLCSim or NetToPlcSim.
NetToPlcSim comes with a pretty thorough manual, see if that can help.
hi,
I have currently also had the same problems, have you then maybe found a solution?
