Connecting boolean signals using Python
Hi! Is there any way to create a connection between two boolean signals with a python script?
See the connect method:
https://help.visualcomponents.com/4.9/Premium/en/Python_API/vcSignal.htm?rhhlterm=connect
Thanks! This worked.
Now I’m wondering if I could connect the boolean signals to “Component path sensor” behavior via Python script?
You need to create a Boolean signal behavior in the component and then assign it to the sensor behavior:
https://help.visualcomponents.com/4.9/Premium/en/English/Component%20Modeling/Behaviors/Sensors/Component_Path_Sensor.htm
https://help.visualcomponents.com/4.9/Premium/en/Python_API/vcBehaviour.htm?rhhlterm=path%20sensor
Then you can connect your Boolean signal to some other signal.
