It’s possible to use Visual Components 4.5 to connect the software to a Web Service ?
what you want to achieve?
I want to connect my software Visual Components 4.5 to send differents datas like a BOM for example to a Web Service. It’s possible to use an add-on Python for that because I think the software doesn’t recognized the library SOAPpy which used for Web Service ?
Regards,
Deros
fot stuff like a BOM I would try my luck over a .Net-PlugIn. Because there you can use .Net and and I also think that SOAPpy will not be at the supported libs… ![]()
Thanks you for your informations.
Do you have ideas or similars tutos for realise this because I never don’t coded in .NET ?
If I have my BOM coded in python and extract with Visual Components in csv can I research this csv, call this in development .NET and send this to Web Service ?
This second part is interfaced in a panel present in Visual Components and at the click of a button the csv is sent to the Web Service.
I understand now why Soappy isn’t recognized by Visual Components.
Regards,
Deros
