I have created a component (control panel potentiometer) that outputs a value through an Integer Signal behaviour. I have created a display component capable of showing a value as text with an Integer Signal behaviour used as input. However, i can’t figure out how to connect the two. I was expecting, that the Integer Signals would show up when i click “Signals” in the Home or Modelling tab (just like the boolean signals). But this is not the case.
So, how do you show/connect Integer signals?
The IntegerSignal deos NOT show in the list of signals. But it shows up in the Interfaces list.
I still defined the IntegerSignal as a behaviour in the component. But then i also added an Interface behaviour and in that interface configured a signal field that points to the IntegerSignal. I need, of course, to configure a similar interface in the component I want to connect to. And then i can connect the signal via the interface list.
