Hi there,
i just started testing VC - Professional. Im trying to connect one component which is moving on a conveyor with another component which is a child component on a works process. Later i want to disconnect those components. The component moving on a conveyor should keep doing so and the second component should move on a works process close to the conveyor.
I found two API methods that could do the trick for me: app.connectComponents(c1, c2) and node.attach(). The connect method works well for me but i struggle to get the disconnect part to work. Is there a method or trick someone know to do so?
Thank you in advance
