Components don't move on 3D PDF VC PRO 4.10
Hello, after updating to VC Pro 4.10, any 3D PDF recorded simulation freeze all components that are created and deleted during the simulation at their initial position. For example if a component it’s created on a conveyor, moving by a robot or human, and leave it on a second conveyor to disappear at the exit node or sink, the simulation runs normal at VC or even at VCAX export file, but at 3D PDF, the component remains in the position it’s created at the first conveyor. This also happens in components created in an static component like fixtures or tables.
This affects any component created and deleted during the simulation. I recorded a simulation in parts to verify, and all the components that reach the final of the process being deleted at the exit of a conveyor, or by a sink process or by python programming, keeps frozen at the initial position, but the components that don’t reach the delete part does move as it they should. This even happens in the most simple simulation, having a part created at the start of the conveyor and being deleted at the end, all parts that reach the end are frozen in the initial position in the 3D PDF.
I’ve recorded the same simulation in both VC PRO 4.9 and VC PRO 4.10 and this only happens in 4.10, even if the simulation it’s created in the new version.
Have you seen this issue?
Thanks for your help.
