I have another (admitedly very basic) question. How do you access the Component property from the ComponentAddedEventArgs?
I serched the forum, watched the tutorials and the webinars dealing with event handling but couldn’t find an example where the EventArgs are accesed.
Could someone please give me an example (or point me in the right direction) of how to for example print out the name of the component that was added to the layout?
I was wondering if anyone knows how to do this correctly in VC 5.0?
Documentation says that IApplication.World is obsolete and you should use ISimWorldManager.ActiveWorld or ISimWorldManager.StaticSimWorld instead.
However I was not able to successfully get a handle on this class/interface. If I use inverison of control I either get an error or the plugin fails to load. I was not successfull with other import methods either.
