Description: I am facing a synchronization issue between a Component (.vcmx) and a Layout (.vcmx). I am looking for a way to force an update without re-inserting the component to maintain collaboration and positions.
Steps to Reproduce:
Created a custom component and saved it as a
.vcmxfile. -
Dragged this component into a Layout.
Saved the Layout WITHOUT checking the “Save Components with Layout” option (to keep the layout file size small and maintain external referencing).
Modified the original component file (e.g., changed a script or a property) and saved it.
Reopened the Layout.
The Issue:
The component in the Layout does not reflect the changes made to the source file.
The Layout file size remains very small, confirming it’s an external reference, not an embedded copy.
Restarting the software does not trigger an update.
VCID remains identical between the source and the instance in the layout.
Environment:
Visual Components Version: [5.0 OLP]
OS: Windows 11
Questions:
Where is the “old version” of the component being cached if the Layout file itself doesn’t contain the geometry?
How can I force the Layout to “Reload” or “Sync” with the disk file without deleting and re-dragging the component (which breaks PnP and specific configurations)?
Is there a Python command or a specific setting to clear the ModelCache or force a metadata refresh for external references?
