Yes, the two conveyors/two paths is a workaround. I hestitated from suggesting it because it might complicate the logic of robot program and signal connections. But good that it worked out in the end.
Well, in the end it seems that the two conveyor method is simpler than having only one conveyor.
Sometimes it is easier to do things the long way.
Thank you zesty for all your help and cooperation.
I wish you all the best!
Hi there…
I know this is a bit off perhaps, but I was struggling with the Feeder that it did not like to use a part. I got the error: Failed to read component (component is layout)
The reason for this is that the .vcmx file was saved as I normally would save the file, i.e. CTRL+S.
But if you go to the model tab and then click “Save As” in the component ribbon, then the feeder stops complaining ![]()
Yes, saving from the File menu saves the layout and Save from the Modeling tab ribbon saves the component. These use the same file extension .vcmx but layouts can’t be used like components.
Hello CLH,
This is correct. As this is an old topic, I will now close the thread.
br,
lefa
