I am currently working with the vcCollisionDetector, setting NodeListA and NodeListB and checking if a collision happened with testOneCollision.
I found out that a collision is only detected, when the bounding boxes are colliding. A collision is NOT detected, when a node from NodeListA is inside a node from NodeListB.
After that I thought of using vcVolumeDetector. However, using this detector requires to set (and always update) the corners and the transformation matrix in case this node is moving.
Is there a way to detect a collision even when the node is inside another node with the convenience of using NodeListA and NodeListB.
The reason why I like the nodelists is because I can change them without carrying about setting and updating corners/transformations and I am able to have multiple nodes in either list.
Thank you for your help!
PS.: a simple example is attached
Test_CollisionDetectors.vcmx (23.7 KB)
