i would like to speed up the simulation at certain points during my simulation. I started the simulation with “real time” and used this code structure:
# Real Time Approach: sim = getSimulation() # do something sim.SimSpeed = 2.0 # do something fast sim.SimSpeed = 1.0 # do something
The problem is that when I set the SimSpeed to 1.0 again, a time jump happens and the simulation is stuck for a view seconds. When I do it by hand (setting it at the simulation panel) its no problem to switch to other SimSpeeds.
I found a workaround using “virtual time” and approximating the speeds to get a similar behaviour.
# Virtual Time Approach: sim = getSimulation() # do something sim.SimSpeed = 0.036 # do something fast sim.SimSpeed = 0.018 # approximately real time speed # do something
This helped, not to get “time jumps”.
I was wondering if there is a way to prevent this “time jump” using real time.
Edit: Is there a way to “Fast Forward” during a recording? It looks like changing the simulation speed does not apply during the recording (manually, as well as programmatically).
Thanks in advance.
