I want to change the Value of a variable in the Routine Properties of a Process Node during the simulation. The variable I want to change is “need”, to stop TransportIn and start TransportOut. The script below works fine but need_Buffer.Value = True won’t assign the new value to the Routines Properties Variable “need”.
thanks for your help in advanced
