Hi there,
I was using quite alot of data series in a chart while using statistics. After twelve data series, the list of colors that were used in the first twelve repeated itself. When I wanted to set the color for the lines, I found this:
app = getApplication()
dashboard = app.Dashboard
tab = dashboard.SelectedTab
chart1 = tab.Charts[0]
data_series1 = chart1.Series
color = vcVector.new(0,255,255)
data_series1[1].Colors = [color]
I was assuming that I could give RGB code as a color since (1,0,0) gives red, (0,1,0) gives green and (0,0,1) gives blue. Strangely, (0,255,255) resulted in a very dark color instead of cyan that I was looking for.
Does anyone here know what color code is used by Visual Components in their statistics? Or can I link the lines to an existing material from the material library?
Thanks for your help!
