Change Frame visibility
Dear All,
I am looking for a way to change the visibility of frames from frames with a .net add on.
In fact, I want to have the option to do the same as this buttons in the interface.
In the documentation, I think this is the class I need to use, but I can not find an object from this class in the application, window, camera, …
Can anyone give a hint or an example how it would be possible to change the visibility of the frames?
Best regards,
That FrameTypeConfigElement is for storing those frame visibility settings in the user config file.
I think the easiest way to temporarily change what frames are visible is to use the ILayerControl interface.
You can [Import] it or use IoC.Get<ILayerControl>().
There are also some UI-side interfaces for manipulating those settings, but it is much more complicated.
Thank you for the reply.
This is indeed a working solution for the problem!
