Hello, I would like to send a signal from a process node to a crossing conveyor. By this signal, I need to reroute conveyor accordingly.
It would be my first time creating and sending signal. Please consider this ![]()
Thanks in advance
Thanks in advance
Different products come in different frequency, that’s why I need such a transport solution. Im open to discuss alternative solutions.
If all lanes are occupied, pallets need to accumulate on the right
Hi serdark,
If I understand correctly, this is what you want right?
Uploading: CrossingConveyor_SignalControl.mp4…
This is the test file I used:
CrossingConveyor_SignalControl.vcmx (320.5 KB)
Let me know if this is what you are looking for, then I can elaborate on how you can do this
This is exactly what I’m looking for. You are legend. I figured it out by looking at your design. Now I’m facing a little problem, when I try to click “Signals” to connect them, process nodes are gray and I can’t click them.
That´s because there is no signals modeled on those ProcessNodes.
Signals are made from Behaviours options on the modeling tab.
