You can use a DWG or a DXF as an underlay for a factory layout.
Is this also possible by using a PDF as an underlay?
If yes, is there any instruction on how to do this?
Regards,
Marcel
Regards,
Marcel
use dxf or dwg, you can reference Components in edges and so on.
PDF is not supported!
If PDF is your only option take a photo of it and scale it to real measurements.
Actually, that was the easiest solution, thank you.
Thanks,
Yes, I agree, but what if only a PDF is available?
