Blenderer add-on booster
This is the booster for the Blenderer add-on.
  1. You still need Blenderer add-on, but no modifications are required.
  2. No more glitches.
  3. The simulation speed can be adjusted to full speed.
  4. The simulation will automatically stop and generate a video.
Unzip and place it in the VC installation folder. No configuration is needed, it will be applied automatically
booster
VC 4.10 Plugin.BlendererBooster.zip (2.8 KB)
VC 5.0 Plugin.BlendererBooster_vc5.dll.zip (2.8 KB)
@idkfa Do I need to install it together with the Blender plugin? Or just need to install this latest plugin?
Hello @idkfa I have been using Blender version 3.6.23 with Visual Components, and it works perfectly. However, I recently tried updating to Blender 5.0.1, and it seems to be incompatible as the rendering fails.
Could you please confirm the latest stable version of Blender that is officially supported by the current Blenderer add-on? I am considering moving to Blender 4.2 LTS; would this be the recommended choice for professional use at this time?
Thank you for your guidance.
The truth of this issue is that the big Blender version update changed some APIs as well, you can use your IDE helper and ask him to adjust it according to the version profile of blender.
The Blenderer thread says “version 3.6 LTS recommended”, so I assume nothing after that is tested or works.
Thank you so much for your answer
