is it possible to call Blender AddOn over .Net to create awesome Renderings?
Thx & Regards
Thx & Regards
Well, it is open source so you could probably make it possible.
There is limited API to call any Python command from .NET in the IApplication interface.
See these:
IPythonCommand FindPythonCommand(string commandName)
ExecuteCommandResult ExecuteCommand(string commandName, PropertyCollection parameters)
ExecuteCommandResult ExecuteCommand2(string commandName, params object[] args)
bool ExecutePythonCommandMethod(string commandName, string methodName, string[] arguments, out object result)
The types of parameter arguments you can pass is limited, but you can work around that by using strings.
