Behavior in Conveyor Curves
Hi all,
i have a question about the VC Conveyor behaviors.
If use a straight piece of conveyor, products arrange close after each.
If this “batch” of products runs into a curve, it creates a distance.
For my application this is not good and i do not understand if there is any parameter that i need to change to change this behavior to act in the same way than the straight pieces.
Paramters are equal between straight and curve.
Here is a picture of what i mean:
Anyone some proposal for me?
thx, Florian
I do not have answer to your question. But have a broader question along the same line: How to generally set/ manage minimum distance between products on a conveyor? Maybe someone knowledgeable about the topic can answer this as well. Thanks!
The Conveyors have a parameter called Segment Size. For my understanding this would help in your case to create a minimum distance between products.
I don’t know if the answer is correct, but try disabling SpaceUtilization among the properties of Modelling - Behaviour - Path as in the picture!
Please refer to it
yes, i already tried this, but deactivating “SpaceUtilization” Parameter causes a lot of weird situations when entering Conveyors with “Space Utilization” acitviated and at all my Process Points where i handle the Products on the conveyor (like stopping, moving from Component Container to a Proces Step)
Thanks! So if my conveyor is 1000 mm and I set the segment size to 100, there will be 10 products on the conveyor with distance between front edges of two products = 100 mm, right?
correct, from Help File:
Set the path’s DetailCurveMotion as false. This option is not shown in UI but it needs to be changed via Python.
vcMotionPath
great, this is what i was looking for!
Thanks a lot for your help!
br, Florian
now i tried to set DetailCurveMotion to False on Curve 1,2+3. Now the Product run into the curve without gap, perfect. But a the end of the Curve the gaps get created.
This happens on both lines, although there is another curve after (which has also the parameter disabled) or there is a straight Piece…
Any ideas?
Going from the curve into a straight section will cause the following with bounding boxes of products:
Unfortunately setting the DetailCurveMotion as false for also the straight section does not fix it.
In case of VC-branded library conveyors, you could adjust the ConveyorStartOffset and ConveyorEndOffset parameters of the conveyors so that the PnP interface’s frame is offset a little bit from the start/end of the conveyor. This way the curving path will go straight a few dozen millimeters more before the products flow from the curving path to the straight path.
Or if the conveyors are proprietary models, just moving the first and last path frame of the curve will do the same.
Thanks a lot for this, works!
br, Florian
Good morning to you,
i would like to highlight this topic again.
During the last weeks of my simulations on the Layout with theConveyor topics, i identified a strange behaviour.
Sometimes, and that happens really very rare, the Curves, which have the Offset and the “DetailCurveMotion” = False, do not release the products.
This is the picture of the running simulation (the simulation worked for about 2 hours, than it happened):
Maybe somebody has an idea what could cause this.
Parameters are set like this:
