AVG path select
Hi, Whilst reading and viewing the tutorials I have yet to see how you can assign one AVG to go on a certain route only, My paths cross over each other in several places and whilst I can set capacity to 1 there are points in the process another AVG will use the assigned path as a shortcut.
Is there any way to stop this from happening?
You could maybe define some Pathways as “OneWay”, so that the AGV can only drive in one direction and not take shortcuts?
Otherwise, if you really want to define exactly through which points/pathways the AGV are driving from one process to another, you can use Missions
