I am attempting to do a task using steel door for safety purpose using VC - Premium 4.8. Despite several methods and signal connection, the steel door is not properly synchronizing with the human resource movement.
The file is attached for your review. Please help me to resolve this issue.
Are you talking about the problem where the door has already closed when the last worker takes the finished product out from inside? This is because the process prematurely sets the state back to Idle. In fact, adding a 10-second delay or adding a check to see the position of the person can both solve the problem
