I need some help. In my layout i have a robot that has 4 different grippers. Based on the part is should pick the right gripper to grab the part. How can I achieve it?
Hello, do you want to do that using process modelling (easier) or robot programming?
With process modelling, you can for example organise your different product types in different flow groups and define in the corresponding transport links which tool is used :
With robot programming you would need to know which product is there and for example send a signal to start a different routine to pick up a gripper corresponding to the product/signal and then pick up the product…
I’m not sure which component would be able to send a different signal based on the part. I would probably use a process node (from Process modelling) and with an “if” or “switch” loop, send a different signal based on the product type. → you would just use the process to send signals to the robot and then programm the robot…
